TwinTurbo.NET: Nissan 300ZX forum - Re: Clatter Noise
Subject Re: Clatter Noise
Posted by txq45 on March 03, 2011 at 10:02 AM
  This message has been viewed 155 times.
In Reply To Clatter Noise posted by buckethead151 on March 03, 2011 at 08:50 AM
Message Are you sure it's not a bearing knock?
If you reduce the load on a cylinder (that has a bearing problem)the noise will go away..
Most bearing failure is on the 5 and 6 cylinders on the 300zx..
You could try removing the injector and coil connectors on the number 5 then 6 cylinders, one at a time.. If the noise goes away.. you know what it is..
Hope it's something less expensive
Nistune Dealer
Parts www.aaa-hiperformanceauto.com
ECU socketing ECU eprom upgrade
